跳转到主内容
The Asus X53E is a 15.6-inch Windows laptop released by Asus in 2011.
15 个问题 查看全部
Lcd Monitor not work
Hi to all,
if I move the notebook on the right or give him small blows always on the right side near the battery , the screen goes black . If I do the same thing on the side left box nothing happens .
I would like to open the pc , what can I check?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Sounds like you either have a loose connection or an IC that has dry solder balls underneath and banging it makes it temporarily loose connection
这个答案有帮助吗?
得分 1
1条评论:
Hi, thanks for the response; so i open the notebook and check only if there is a cable lifted ??
完成的
添加一条评论
添加你的答案
Alex 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 127
