跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
No response from phone even with different components
phone was left to me by a customer was dropped on the floor said the lcd was sending lines through... . OK so first tried to plug it in and hard reset it no response. tried new screen new battery and charge port (and plugging it in to power on). NO response. using a test phone i tried the customers screen to see the damage, it came on briefly through my test phone( with no damage) and shut its self off, not sure why. But Im only left thinking the mother board is the problem. If anyone else has a suggestion for this loop i seem to be stuck in that would be AMAZING! Thanks >v<
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I would check to see if the backlight pins are shorted,this will cause the screen to shut off. Also when you say the screen shut off, is only the backLight shut off or the LCD too?
这个答案有帮助吗?
得分 0
2条评论:
the whole lcd i do not see anything from the screen even without the back light Im more then frustrated , I am lost
完成的
Try shining a light at the screen and see if you see anything. I mean that the backlight may be nonfunctional, but the LCD is still displaying something too dark to see because of the nonfunctional backlight.
完成的
添加一条评论
添加你的答案
Veronica Royal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 65
