跳转到主内容
This is an 8.0 mega-pixel digital camera with waterproof and shock resistant capabilities. It also includes features such as 3X optical zoom and face detection.
8 个问题 查看全部
LCD screen is black
my cameras lcd screen is black i cant see anything it still takes photos tho but i cant see them?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
I am having this problem as well. Did you ever find an answer? Stylus 850 SW camera, screen is black, lens is open, I take a photo and plug camera in to computer and there’s a file there but its just a black rectangle
完成的
添加一条评论
1个答案
Hi @mormongirl782
Can you view the menu settings in the camera’s LCD screen?
If so then the LCD screen is OK and since you can “take” pictures and download them, this proves to a degree that the motherboard is working OK also.
The problem appears to be with the camera’s CCD image sensor or its’ connection to the motherboard.
I cannot find a replacement CCD sensor online or even a teardown of the camera to see how to open it to gain access to the sensor etc to check if anything was loose.
Given the cost - examples only of the camera, it would be doubtful that if the problem was a faulty sensor and not just a connection problem, that you could source a replacement sensor any cheaper than replacing the camera itself.
这个答案有帮助吗?
得分 0
1条评论:
Hi Jayeff!
I can view the menu settings in the camera's LCD screen, yes.
When I take photos and download them/hook the camera in to view on the computer, it's just a black rectangle :(
完成的
添加一条评论
添加你的答案
tamarah cooley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 14
总计 729
