Screen only shows gray and black lines?
My Tab only displays black and gray vertical lines, but I can hear that the unit is powered on, what might be the problem? Is it repairable? Thank you!
Looks like the LCD for this went bad or became loose from the board itself. It is definitively repairable, but I do recommend that you purchase the LCD and Digitizer assembly if you are going to do this yourself.
这个答案有帮助吗?
I had the same problem replaced the screen and digitizer and still it's black with gray lines
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 749
