跳转到主内容
第二代 Moto X(市面上延用Moto X名称)由Motorola公司开发的安卓智能手机。于2014年9月5号发售,它是2018年Moto X初始版本的继任者。
45 个问题 查看全部
Why does my phone keep on restarting then shutting down again? Help!
For the past two days, my phone has been restarting itself to the Motorola logo, then turning itself off, over and over again. I've tried to externally factory reset it and clear the cache partition. Nothing has worked and it always goes back to the Motorola logo only to restart again. Does anybody have any ideas to fix this?
Note: The night before I put my phone to charge at 3%, but it was charging for the entire night. The next day it was in the condition it is now. Don't know if that helps.
Please help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
The micro-USB port needs to be replaced.
完成的
添加一条评论
3个答案
Download the stock firmware and flash it via fastboot.
Get into fastboot mode by holding power+volDown until you see the fastboot screen.
Here is a more detailed rundown of how to flash the images.
https://motorola-global-portal.custhelp....
这个答案有帮助吗?
得分 0
添加一条评论
I would check your charger. What you describe sounds like an extremely flat battery. Plug in a different charger that you know works and see what happens. Otherwise you may have a problem with the charging board or circuit
这个答案有帮助吗?
得分 0
添加一条评论
Probably, the micro-USB port needs to be replaced. UbreakitIfixit, a national chain could fix it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Eric Amaro 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 333
