跳转到主内容
The first generation Audi A4 debuted in October 1994. The 1995-2001 A4 was built on the Volkswagen B5 platform.
6 个问题 查看全部
Getting open circuit for my fuel injectors 1thru 6?
1998 Audi A4 2.8L: No misfires. Ohms on injector are fine fuel pump is good.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Are those the obd codes you are getting (p1237-P1242)? Maybe the fuel pump relay? Does it run then? Is there anything you notice about how it runs? Maybe a lag when you hit the gas, or bad gas mileage? Have you checked the fuel pressure?
完成的
添加一条评论
1个答案
It is running well. I dont have the tools to check fuel pressure. No lag iam think fuel relay
这个答案有帮助吗?
得分 0
1条评论:
I thought of another check, you probably already did this though. Measure the resistance to ground on any of the fuel injector connector ground pins. It sounds like if that is even 2 Ohms (I picked that number out of the air), you will get that code. And the ECM should compensate for it by sending more power through, thus having no noticeable decrease in performance.
完成的
添加一条评论
添加你的答案
BJuan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 11
总计 443
