跳转到主内容
A tablet released in September of 2015 by Amazon featuring a 7 inch multi-touch screen display. Model Number: SV98LN
Screen is white after digitizer replacement
I replaced digitizer on this device. The screen is completely white, but if I tilt the device I can see a picture. The touch function works. Is there something that I'm missing with this repair? I double-checked all connections. The problem seems to be that there is too much backlight. Thanks for your time.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
Taking a guess, but maybe it's something to do with the polarizing filter. Try a different digitizer from a different seller and see what happens.
完成的
Could you explain what a polarization filter is and its function or what it looks like?
完成的
添加一条评论
5个答案
最有帮助的答案
Okay, I found the problem with the white screen. There is a special plastic film that is tinted on the inside of the digitizer. I took my old digitizer and waved it over the display and I could see it perfectly, I took the new one with no plastic tinted film and it was white screen. I was able to peel this plastic film off the inside of the digitizer without damaging but the problem is going to be getting all the old adhesive off and trying to put new adhesive on and avoiding any impurities such as lint, dust. Does anyone have an idea where I could find a polarizer like this........ here is a picture.......
This is for a Kindle Fire 7 2015 edition. I believe it's a seven inch screen.
这个答案有帮助吗?
得分 1
2条评论:
did you ever find a replacment
完成的
Thank you for taking the time to post this information. I just fitted a digitiser myself and had exactly the same issue. I only wish I'd read your post before I fitted it! Nonetheless, I was able to remove the digitiser and the film and then put the digitiser back on and it's perfect now. What a relief.
完成的
添加一条评论
I too had this issue. I could barely see an arrow and 2 rectangles at the bottom left side. I did not have the glass stuck back to the tape, so I lifted it up and found that I missed pulling a protective cover sheet off the inside of the glass. I pulled it off and I could see the screen normally. It is working perfectly now. I hope this helps someone else.
Garry.
这个答案有帮助吗?
得分 1
1条评论:
fantastic Garry, i just had same problem. your tip fixed it!!! you are a star! :-)
完成的
添加一条评论
I did not. I Even tried ordering a polarizing sheet from a company that specializes in polarizng film and it didn't work
这个答案有帮助吗?
得分 0
添加一条评论
I seem to have the opposite problem - the screen is far too dark! If I look directly at the screen I see nothing, if I tilt the screen to nearly 90 degrees from my eyeline I can see display. The touch screen appears to work.
Is this likely to be related? maybe 2 polarising films applied instead of 1?!
这个答案有帮助吗?
得分 0
添加一条评论
my screen was only visible when angled.
as Garry said, there was a protector screen on the inside of digitizer screen as well. removed it an works perfectly!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
CluelessInSeattle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 25
总计 3,049
