跳转到主内容
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
299 个问题 查看全部
Runs rough when temp sesor is plugged in
I have a 1988 Chevy k1500 with a 5.7 350, upon first start up you have to have the temp sensor plugged in otherwise it will spit and sputter, and run like crap. After ten minutes or so, you have to unplug the temp sensor, otherwise it will run like crap spitting and sputtering. I have replaced the plugs, knock sensor, the ESC module, both temp sensors, also replaced the tank, sending unit, pump, and fuel filter. Next on the list will be the plug wires, cap and rotor, after that I'm not really sure what it could be, any help will be much appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
How did this start happening? Like what were you doing? Lots of times nothing you did caused it, just a bad part(s). Did you buy it that way? Just clues to the puzzle.
Odb 1 doesn't always throw a code when it's a small flux.
Does it throw a code? If not then:
Check your - vacuum lines, egr valve, o2.
*If vacuum lines show any wear then check them (careful they are fragile)
*Clogged egr happens but no very often, or even stuck open.
  • test the ohms on the o2 sensor wire.
I would also test the sensors you replaced especially if you bought off brand, not common but they can just be bad.
It could be your catalytic converter.
这个答案有帮助吗?
得分 0
添加一条评论
Pretty sure you have TBI. Before you put plug, wires, etc... try the fuel pressure regulator rebuild kit. It's about 40 bucks and takes about an hour to an hour and a half to do. The diaphragm gets dried out and rusted (it's part metal) and can make it idle rough enough to die. There are a few videos on you tube for guidance. Common problem with TBI.
这个答案有帮助吗?
得分 0
添加一条评论
There is two different temp sensors, one runs the gauge or dash light. The other one is how the engine controller receives its info. It will throw the fuel trim of so bad the car will run like crap and dump a lot of gas. My name is TJ
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
187mauler 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 30
总计 3,072
