跳转到主内容
加入维修社区 - 创建账户
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
Laptop won't turn on.
Plug the charger in and no charging lights come on. Power button makes a clicking sound when pressed. New after market charger. Battery reads 3.2 when tested on ohms meter. What is the problem? Also, looked at ram and it say 2GB. I thought this model was minimum of 4GB.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The fact you don't even get a charging light could mean that the charge port or power board is faulty.
It's tricky to diagnose without a good root around but my next guess would be the CMOS battery could be dead.
If replacing that didn't sort it I'd look to the RAM. Faulty RAM would stop the BIOS/CMOS from even starting, but then again I think you'd still get a power light.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John Davis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 603
