跳转到主内容
The Asus Zenbook UX31A is a laptop released in June of 2012. It is a member of Asus's Ultrabook line. It features a 3rd generation Intel Core I7 processor and a full HD IPS Display.
36 个问题 查看全部
Flickering Screen on battery power
Hi everyone,
since i changed the keyboard on my asus zenbook i noticed a strange phenomena...when running on battery power the screen is flickering almost all the time. But this only happens when i am on battery power. The screen is also very dim.
When i use the ac everything works fine, i get full screen brightness and there is no more flickering at all.
I am running on windows 10, adaptive screen brightness turned of, as well as intel hd graphics battery safer mode...latest drivers installed.
I checked all the ribbon cables and connections, everything fine so far. It would be great if someone could help me out.
Cheers
Ben
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
Dears
I have same issue, did anyone find the solution for it.
完成的
添加一条评论
5个答案
Hi
If you can get into the BIOS setup of your machine, do you notice the same problem? If so, it might have something to do with the hardware. Otherwise it might be a driver issue of some sorts? Perhaps also try disconnecting the keyboard altogether. It is possible that the keyboard backlight is driven by the same power supply as the LCD backlight and a shorted keyboard backlight module is causing the ppowersupply to malfunction.
这个答案有帮助吗?
得分 0
添加一条评论
Hi Larry, thanks for your quick reply. I thought so and did a check with the bios running and i got the flickering as well. So it seems to be a hardware related issue. What i don't understand is why this is only happening on battery power and not with the ac plugged in...
这个答案有帮助吗?
得分 0
2条评论:
Sorry about the late reply. I was meaning to get back on here!
There's a good chance that something is up with one of the voltage converters on the motherboard. The battery voltage and the adapter voltage are a bit different and when on the lower voltage, a weak converter might have trouble producing the high voltage needed to run the display.
if you're up for the task of attempting motherboard repair, perhaps you can find a schematic online and perhaps see how the power circuit is driven in the laptop.
完成的
Hi Larry, thanks a lot for your reply. I dont think i can handle a motherboard repair on this level, as i am no technician, just an experienced amateur. Do you think it will be expensive to get a pro to look after the problem?
Cheers
Ben
完成的
添加一条评论
I have the exact same problem after I opened the laptop (Asus UX303LA) so I could tighten the hinges on the display. I have looked after a new motherboard and they varry between 300 and 450 Euros. A bit expensive in my oppinion. I have updated the BIOS and of course it didn't help. The problem is obviously on the hardware side. It's a pitty since the battery was lasting around 6 hours.
这个答案有帮助吗?
得分 0
添加一条评论
Hello everyone. Same problem here. Was having the same problem plugged in or not. Changed the battery settings to high perfomance and now I can watch a movie plugged in atleast
这个答案有帮助吗?
得分 0
添加一条评论
Hello every one, I can't say whats going on but I encountered same problem but screen would Flickr all time, then after examining , problem was in video cable.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ben Stremming 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 13
过去 30 天: 24
总计 9,709
