跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
Why is the touch screen so erratic after several replacements?
I have had this problem with several different iPhone 5Cs.
None of the iPhones are liquid damaged but i have had a few where the screen is just erratic a few hours after changing it. I have tried screens which I know 100% worked before but the customer still comes back and says that the screen is erratic. I'm tearing my hair out! Is it a software issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Are you using an anti static mat? I have never had that issue and I always use one and ground myself. It's also very possible the screens you are using are just going bad very quickly. I would try getting higher quality screens first because I would bet that's really the problem
这个答案有帮助吗?
得分 1
2条评论:
I haven't been using an anti-static mat but i have repaired hundred of 5C screens and this has never happened before. It has only been in the past few months which is why i thought it might be software related... and the screens aren't cheap quality, i make sure I buy high-priced screens to get a good quality version but they're all seeming to mess up the phones...
完成的
did you figure out what was wrong with it and how to fix it ?
完成的
添加一条评论
添加你的答案
Max Shepley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 50
