跳转到主内容
The PSP 3000 was released in the U.S. on the 15th of October 2008.
92 个问题 查看全部
Is the PSP 3000 motherboard Hot-Swappable?
I recently tried to update my psp firmware, though,at the time, I had lost my battery cover. As you would expect, my battery popped out and there we got a full brick!
Anyways, I read on a forum that changing your motherboaard fixes the brick(?), and I was wondering if the PSP's motherboard fixes the problem, and if it does, is it hot-swappable or is there a device key bound with the rest of the system?
Thanks in advance, Chrysostomos
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
the motherboard is not hot-swappable. you can swap it though for the same one working...
http://www.youtube.com/watch?v=t7sWU1bzd...
this could prove cheaper...
i cannot tell you, if it works so please take it as without guarantee..
这个答案有帮助吗?
得分 0
1条评论:
Thanks man I will try! You really saved me some bucks there! I was just about to order a motherboard! I will try the pandora- magic mem stick way. And if it does't work, np its just like 30 bucks! In the end I can just send it for repair!
完成的
添加一条评论
Also I think you confused "hot-swapping" with swapping. Hot-swapping means you can remove and replace a component without having to power the system down.
这个答案有帮助吗?
得分 0
添加一条评论
Hi. Pandora battery can't be used to unbrick psp3000.
这个答案有帮助吗?
得分 0
1条评论:
...No, as the Brite 3000, being "different", will not accept a Pandora Battery, and it just BRICKS IT MORE!!! And that's what you DON'T want.
--Sent from my Raspberry Pi 3 using Chromium 51
完成的
添加一条评论
Bro if you not break it with cfw and the damaged from you buy motherboard… If The psp not damaged and only cfw break system you can see youtube to unbreak psp 3000 easy…
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chrysostomos 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 8
总计 3,459
