跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
The brand new screen I installed has backlight banding issues
Hello,
I purchased and installed a new Full Assembly fix kit for my wife's iPhone 5s. It powered up well and install was a cinch but there are dark bands along the top of the screen that I'm assuming are related to the backlight. Any ideas? Do I have a connection that wasn't made well or is it possible the assembly kit was a lemon?
I have a picture of the banding that I will try to upload (not so sure I can make it work).
Thanks!
Adam
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
For future reference, it's impossible for the backlight to cause black banding.
完成的
Good to know, thanks. Figured it was the backlight because I had an LCD tv with the exact same banding issue and according to Sharp it was a problem with the backlight.
完成的
添加一条评论
2个答案
已选择的解决方案
The LCD cable is the easiest (and smallest) of the three ribbons to snap / click in place. I'd give it several attempts to get the cable connected and if its still showing banding you've either got a damaged connector or a bad screen. If it's an aftermarket screen I'd probably be tempted to go with the latter, but check your board... with a magnifying glass if needs to be. Good luck.
这个答案有帮助吗?
得分 1
1条评论:
Thanks Mike. Giving this and the similar advice I got a shot tomorrow when my wife won't need her phone (in case something goes wrong).
Adam
完成的
添加一条评论
最有帮助的答案
Hi
It could be a bad connection from either
only way to check this is to have another screen handy.
I always find if I get banding on LCD, its usually the connection teeth on the clip
get your best magnify glass out... check all the legs are strait and clean.
happy days
Ray
这个答案有帮助吗?
得分 1
1条评论:
Thanks Ray. Getting into it tomorrow with your advice and that of the other poster. I figured it had something to do with a connection unless the screen was just a lemon. Will let you know.
Adam
完成的
添加一条评论
添加你的答案
adamfryer 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 201
