跳转到主内容
Can I replace a 2.33GHz logic board with a 2.50GHz?
I want to upgrade low coast for a machine with more capacity than the current since there is no money for a new
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
Unfortunately, you cannot upgrade to anything higher than what you have now. Here's why:
  • The upper case connector is different in the higher speed models, so you would need a new upper case as well
  • The display in the higher speed models is LED, so the display connectors are entirely different.
  • The keyboard is redesigned with no side tabs on the higher speed models, so you would need a new keyboard.
  • The speaker is shaped a bit differently on the higher speed models.
  • The left I/O board has a different connector on the higher speed models, so you would need a new I/O board.
  • The heat sink has different thermal pad locations on the higher speed models.
  • The fans have a different model number on the higher speed models.
  • There are 3 thermal sensors on the higher speed models instead of 2.
  • The hard drive cable is shorter on the newer version.
  • The optical drive bracket is different and fits differently.
After all of this, it is WAY more expensive than a new machine. Your best bet is to check for deals on complete machines with a higher speed processor.
Sorry!
这个答案有帮助吗?
得分 3
添加一条评论
Can I put new board(i7) to replace:
Model Name: MacBook Pro
Model Identifier: MacBookPro5,3
Processor Name: Intel Core 2 Duo
Processor Speed: 2.8 GHz
Thanks!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bruno 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,392
