跳转到主内容
Screen turn on less than a second
Hello
I just got a problem that my Macbook screen won't work anymore. It will turn on just less than a second then goes black but I can still hear a normal initial sound when power it on.
https://youtu.be/o_gt2_7Z4tI
I already try check the panel connect, disconnect and reconnect not fix this problem. While it goes black, the fan still spin.
So what is the issue? How to fix it? Any one have an advice?
Regards
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
This problem could be caused by a number of things. Did you try to rest the NVRAM?
Step 1: Press Command-Option-P-R quickcly when you turned on your macbook
Step 2: Release those key's if you hear the startup chime for the second time.
Step 3: Does your macbook boot normally ?
To rule out if it is an software related issue, can you run Apple Hardware Test?
Depending on your version of Macbook:
Step 1: Press "D" quickly when you turned on your macbook.
Step 2: Run the tests
or
Step 1: Press Option-D quickly when you turned on your macbook.
Step 2: Run the tests.
Last but not least, can you start verbose mode? Press Command-V quickly after startup
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Piyapol Thanaadirod 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 135
