跳转到主内容
The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
Power button not clicking and barely working
Help, I have replaced the vibrating motor and the power switch. There is no "bounce" or click to the power button, and I can barely get the phone to power cycle.
Can you tell me if there is another part I can replace?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Is it the power flex you have replaced or the actual button? If it is the flex, it may not be seated quite accurately enough for the button to "click" it properly. It only needs to be a millimetre or 2 out of place to not work properly.
Strip it back down to where the flex is accessible and see if the clicker on the flex actually clicks and bounces back out. If it does it just needs resituating. If it doesn't it's a fault with the flex.
If you have just replaced the button, it may be that it is not moulded accurately and you may just need a new button that hits the clicker more centrally
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brian Gordon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 201
