跳转到主内容
4.3" widescreen LCD display with a 333 MHz Processor. Model Number PSP98510. Repair for this device requires common screwdrivers and prying tools.
83 个问题 查看全部
Is there a way to remove Battery connector from the logic board?
I need help with salvaging my PSP 2000. My last attempt before dumping it away.
Basically I think I have a problem with reading the battery... I am suspecting the connector or maybe a fuse ... I've ruled out the battery an charger, they're both working fine on another PSP.
Is there a guide to remove and replace that connector or anyway to find out if the fuse is blown?
Thx.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If you want to check the fuse, you'll need a multimeter on continuity mode. The fuse is labeled... TH or something on it. It's to the left of the white plugged spot for the charger (follow the yellow charger to the area its plugged into). You can then check the fuse there. This is a horrible image but this is the general area you want to look for and test the fuse: Fuse Location (The image is of a 1000 model but the idea is the same for location purposes).
The connector can be desoldered and another one attached. If you're good with a soldering iron you could attach another one in it's place. Chance are though that it's a fuse issue. Check with the fuse first before you go off destroying the charger pins to the PCB.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ali Baba 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 165
