跳转到主内容
加入维修社区 - 创建账户
The following information is intended to help service the Nerf N-Strike Elite Strongarm . The Strongarm was released in 2013 by Hasbro under their Nerf brand.
Darts not firing at full capacity
I have 2 strongarms. Sometime ago they were dropped down a flight of carpeted steps. Ever since then, they don't fire at full capacity. Out of the six darts, one or two might work as they should. I have dissassembled it, and nothing looks damaged, yet they still don't work right. Why could this be? Is something out of alignment?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
已选择的解决方案
This sounds like an alignment problem. it is more than likely that when dropped the mechanism has shifted and under the pressure of the already tightened screws it has stayed misaligned. i would suggest opening it up carefully following a guide on youtube. just take all the parts out clean them up/check if any are broken or cracked (you may have to use a little bit of thumb pressure to check certain parts for cracks) and if all is good just put it back together again carefully lined up. wd40 is good for cleaning non electric parts due to its water displacement and lubrication qualities.
这个答案有帮助吗?
得分 2
1条评论:
Thanks! I will probably just replace them, as NERF guns are not terribly expensive. But, your answer is incredibly helpful and hopefully others may use it to bring new life to their NERF battles. I might try to fix them, but I'm not really that attached to them. Thank you so much! :-)
完成的
添加一条评论
最有帮助的答案
I think it might be because of the fall. The spring might be misaligned.
这个答案有帮助吗?
得分 2
1条评论:
How would I realign it?
完成的
添加一条评论
You might want to look at the air spring...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Michael 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 24
总计 3,546
