跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
LCD screen is blank on 6 Plus
I've replaced a lot of iPhone screens and just replaced an iPhone 6 Plus screen. After resetting it everything worked properly so I screwed down the bracket. When I went to close the screen I noticed it was blank. I hooked it up to the computer and the touch screen is responsive, just not the LCD. What could be my issue? I've tried two other screens and neither of them will work either.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Is there an image , but no backlight? The image would obviously be very faint with a flashlight against it. And of course you would know which screws go where.
完成的
Nope, no image.
完成的
添加一条评论
4个答案
最有帮助的答案
Here is a guide for you: Why iPhone Won't Turn on after Screen Replacement
这个答案有帮助吗?
得分 1
添加一条评论
I fixed it. I unplugged the battery and cleaned the connectors with 99% isopropyl alcohol, dried, and gently reconnected it all. Everything works now :)
Edit: I got up this morning and tried it out and now it won't work again :(
这个答案有帮助吗?
得分 1
添加一条评论
I think it's time to send it to a microsoldering professional. It isn't the backlight filters, because then it would have some kind of image with a light shining on the screen just right. I would guess that it has something to do with the 1.8 volt line on pin 29 of the lcd connector. I could very easily be wrong about that though.
这个答案有帮助吗?
得分 1
2条评论:
I concur. I am sending one board out at the first of the week and am sending this phone in with it.
完成的
Good choice. Let us know what the problem was when you get it back.
完成的
添加一条评论
Could also be that one of the pins bent or broke on the phone itself in the connection on the logic board. Check the pins where the display cables connect to.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
justin epley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 353
