跳转到主内容
华为产品的维修和拆解指南
1882 个问题 查看全部
Is the touch problem in y6 pro software problem or hardware?
The touch in y6 pro is veeeeeery bad is it hardware problem or software problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 13
添加一条评论
5个答案
最有帮助的答案
Enable the developer options by clicking 7-10 consecutive times on the kernel version in your "settings - about phone".
Then open the developer options - animation "off" - transition "off".. It won't secure your problem permanently but it will do for a period of time.. Note* keep your internal memory below 50% used space or else you will face some buggy software instability..
Cheers ;)
这个答案有帮助吗?
得分 1
1条评论:
Protect ur screen from dirt. Keep dry then touch will be ok
完成的
添加一条评论
Follow these steps, it worked for me ;)
1. Try to remove the cover.
2. Disable "Show correction suggestions"
3. Disable "Personilzed suggestions"
这个答案有帮助吗?
得分 1
添加一条评论
I have this model, I did every software solution to solve this but no change, so it's a hardware problem
这个答案有帮助吗?
得分 0
添加一条评论
hi my friend i did 3 steps
1. i turned off all if settings in my keyboard like suggestion
2. i did the above result “Then open the developer options - animation "off" - transition "off". “
3. I got the result and now I can type without any problem
and what happen to this phone I want to tell you about this phone I think this phone when want to use ram and CPU in its system cant type well so you should decrease the usage of ram and cpu in conclusion you turn off every related thing to keyborad and now you have a good key board thats it
thanks
这个答案有帮助吗?
得分 0
添加一条评论
Hard ware problem it touch screen broken
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mohamed 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 12
总计 10,720
