跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
microphone muffled and sounds weird to people im calling
recently repaired my iphone 6 but now everyone i talk to says i sound muffled and there is a weird background noise,i did peel off the blue backing tape and also the orange tape off microphone which i was not sure about,i did fit the rubber back on microphone too,i have purchased another dock port flex to try again ,any advise were i went wrong would be great ,thanks
Update (06/12/2016)
problem solved ,i removed the speaker mesh and it did seem to improve a little,but not enough so i fitted another new dock port flex and its all good...1st one must have been faulty so just got to order a new speaker mesh and all done ,thanks for help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Hi,
Make sure there is no dirt in the microphone hole or dirt on the mesh.
Also, make sure there is a hole in the adhesive for the mic, otherwise it would muffle the audio. :-)
这个答案有帮助吗?
得分 2
4条评论:
thanks for reply ,do you know if i did the right thing by removing blue and orange tape from microphone
完成的
You did yes, did you solve the issue? :-)
完成的
完成的
Not a problem :-)
完成的
添加一条评论
Go to Settings/General/Accessability/Phone Noise Cancellation... Turn Phone Noise Cancellation off.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
garry cavell 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 20,473
