跳转到主内容
加入维修社区 - 创建账户
Remove screw ?
I'm on step 3 of the instructions for installing a new hard drive in my Powerbook G4 15" 1.5-1.67 GHz. One of the 2 12 mm Phillips screws in the memory compartment won't budge. Any suggestions ? Thanks !
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
Stuck screws are very frustrating!
Don't just torque on it blindly, as stripping the screw will leave you in a very poor state.
Try briefly using a hair dryer on the area to loosen things up (don't point the heat at the logic board for long, though!).
Then, with the CORRECT screwdriver size (#00), push firmly down directly into the screw and, while pushing down, turn the screwdriver.
The downward force ensures maximum drive to screw connection, and minimizes stripping.
I hope this helps!
这个答案有帮助吗?
得分 2
添加一条评论
use a magnetic screwdriver. Make sure you have the right size too.
这个答案有帮助吗?
得分 1
1条评论:
Or get someone strong to have a go!
完成的
添加一条评论
添加你的答案
C Cremers 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 17
总计 1,465
