跳转到主内容
苹果公司于2013,11,1发售了更薄,更强的iPad Air ,有太空灰和白色,配置了 定制的A7处理器,并有16, 32, 64, 和 128 GB可选。
577 个问题 查看全部
iPad Air lifting by touchscreen cables after screen replacement.
Hi,
I recently cracked my IPad Air first gen since then I have repaired a few for friends of mine, same model. However I keep having the same issue of the screen lifting by the digitizer cables, this is after leaving them in a press for 2 hours, just wondering if you guys have had the same issue and if possible how to solve it?
Many thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I see this happen a lot, and it's usually due to using a poor quality adhesive or from not cleaning the frame of the device before applying new adhesive. There is a bit more pressure in that area just from the bulk of the cable, but make sure you are tucking it snuggly down into the slot next to the LCD and it should rest well. As for the adhesive, some digis come shipped with adhesive on them. I usually find this to be of low quality. I like to use red double-sided electronics tape and a bit of heat under some clamps to get everything to stay down. Once in awhile the digi will still lift right there, at which point some careful application of a tiny amount of super glue (use a little brush) helps keep it snug. The only issue with super glue is that you don't want to get it on any flexes or the LCD when applying it, as it can make removing the digi a nightmare if you have to open it back up for whatever reason.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tom 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 7
过去 30 天: 9
总计 706
