跳转到主内容
How unlock Sony Vaio BIOS
Hi. I have a notebook Sony Vaio pcg-91311l (vpcej14fx). The user set password on BIOS and forgot it. How can I reset it?
I have tried:
1. Take away the battery for 30 minutes.
2. Sony support want the documents which doesn't present
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
@s0rt3r To reset the bios on most sony vaios you need to disconnect the cmos battery . You need to tear the machine down to the motherboard and locate the battery its usually green and looks like to small round batteries taped together kinda like a figure 8 theres a lead coming off the battery that needs to be disconnected black and red wires. After disconnecting do a static discharge to remove any residual power that could still be in the board . Remove the battery and any power which you should have done before starting then hold down the power button for 60 seconds. I like to leave the computer sit for an hour or two before putting it back together reconnect the bios battery and reassemble the computer. This should fix your bios problem
这个答案有帮助吗?
得分 2
添加一条评论
For Sony laptops is only one way to remove password, you need to have otp pasword,
which u can generate on this website: https://biosbypass.com/remove-sony-vaio-...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vardan Hovsepyan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 6
总计 2,537
