The original charger pin broke was using universal the blue light blinks and takes forever to charge all the way .so metes none of them will even get the light to.come on.
It is probably because the charging brick that you are using is not powerful enough to charge the device properly. You might need a 5v power brick. Also if the battery is drained all the way it might take about 2 hours of charge before it can be turned on again.
由 Joshua Prieto 完成的
