跳转到主内容
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
LCD compatibility between different s3 model
hi guys
I have a Samsung galaxy s3 GT-I9300 that has a broken lcd screen.
I want to fix it with the lowest cost so I thought of buying a used s3 that is for parts, ex " not charging - no signal...etc"
but I want your help on which models are compatible LCD with I9300 ?
SCH-S960L , SCH-I535 , ,,etc
update : I found a cheap sprint samsung galaxy s3 nearby SPH-L710 ,,will my GT-i9300 motherboard fit in place SPH-L710 ?
or is there anyway to fix my I9300 with a good L710 ?
thanks
Abdu
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
SCH-i747 or i9300T while you can get i9300T phones the screens are actually i9300. I don't think the others will fit without grinding or sanding.
这个答案有帮助吗?
得分 3
3条评论:
what is a good to tool to grind or sand ?
完成的
Dremel, Sandpaper, File (The thing used to smooth metal edges and etc).
Honestly you are better off buying a matching screen.
完成的
thanks Ben , the L710 I found is $15 ! so its tempting ,,but I'll search for my model ..
thank you again
完成的
添加一条评论
添加你的答案
Abdu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 1,960
