跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2376 个问题 查看全部
Unknown Rubber Piece from Teardown
When removing the Logic Board this rubber piece fell out and I have no clue where this piece belongs to. By the shape of it it appears to slip onto somewhere. Anyone know where this piece belongs?
http://img684.imageshack.us/img684/3851/...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
18个答案
最有帮助的答案
it was at the top of the logic board, where the L shape begins
这个答案有帮助吗?
得分 5
添加一条评论
Sure....
http://img263.imageshack.us/img263/8572/...
This shows the piece installed.
Just fit it over the logic board. Its in the red rectrangle.
AJB
这个答案有帮助吗?
得分 4
1条评论:
Can you repost the photo?
完成的
添加一条评论
It's not necessary for the function if the phone. It's simply to protect the screens cables from the edge of the phones logic board. A small piece of electrical tape over the edge would work just as good...
这个答案有帮助吗?
得分 4
添加一条评论
Is there a place where I could purchase that black piece? When I disassembled my phone, I saw some black piece fly out and I thought it was something else, so I didn't worry about it. Now I can't find the piece...
这个答案有帮助吗?
得分 1
添加一条评论
here where the black rubber piece speaker of iphone 4s goes!
Where and how iPhone 4S rubber square piece speaker dropped goes
这个答案有帮助吗?
得分 1
添加一条评论
No that peice isnt the same as the pic he showed ive just stripped mine and it goes at the top where the barcode is to stop cables rubbing
这个答案有帮助吗?
得分 1
添加一条评论
I have taken the phone apart a couple of times and have not come across this part. It looks like it is maybe a structural piece that goes along the inner frame of the mid body. Chances are your phone is probably just fine without it.
这个答案有帮助吗?
得分 0
添加一条评论
I have the same here, small rectangular black rubber. does your iphone works perfectly ?
这个答案有帮助吗?
得分 0
添加一条评论
i have the same thing here too and don't know what to do with that piece. seems to have come out when i took out the speaker section.
这个答案有帮助吗?
得分 0
添加一条评论
Memed is correct - that piece of rubber protects the ribbon cables from edge of the logic boardso they dont crack.
这个答案有帮助吗?
得分 0
添加一条评论
Thanks Anthony...is there a way you could illustrate how to install it?
这个答案有帮助吗?
得分 0
添加一条评论
Thanks!
这个答案有帮助吗?
得分 0
添加一条评论
Peculiar, I've taken my iPhone 4 apart with the utmost care and have not ever noticed that little rubber piece. Wonders if mine is there at all. -Shrug- my two cents.
这个答案有帮助吗?
得分 0
添加一条评论
this part is out of my iphone 4. i don't think it has anything to do with my iphone not being able to find any service though.
这个答案有帮助吗?
得分 0
添加一条评论
Haha.. Thank goodness I wasn't the only one. Googling "iPhone 4 lit" predicts "little piece" which I found more than amusing. Truthfully I didn't think I would find an answer but sure enough, right back at iFixit. Thanks so much for the photo Anthony. Much help..
这个答案有帮助吗?
得分 0
添加一条评论
i threw mine out because i had no idea where it came from ,now i keep loosing signal ???
这个答案有帮助吗?
得分 0
添加一条评论
It seems like not all of the phones have this part i did one today and it was not there and im very careful about being sure that i dont lose this part.
这个答案有帮助吗?
得分 0
添加一条评论
Took my phone apart last night and this piece fell out. I reassembled without it, and now the screen doesn't work at all. Any chance this could be responsible? I know the phone is on because it vibrates when plugged in, and the voice command works, but nothing on the screen shows up.
I'm going to take it apart again and check for breaks in the LCD cable and put this piece back in. We'll see...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
richardtong 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 37,854
