I suspect that it may be a spring that pushes the paper tray up to the feed position when inserted. Do you have a picture of the tray and a picture of the feed assembly?
I think this just happened to me... what do I do if the spring is broke? Its hard to see into the printer via the top draw paper tray/feeder. I have a Interpret S405. Thank you.
There are springs that drive the feed wheels, each set of wheels (could be a plastic rod with with rubber wheel looking things) each rod should have a pair of springs, find one with one spring and put the other back on.
2条评论
由 DrGlowire 完成的
由 Regina Warren 完成的
