How can I fix the antena of the NIC from a laptop?
Hello,
While i tried to fix some problems of a laptop, accidentally I broke the antenna of the NIC. The wire and the gold prong just broke off. I tried to reconnect putting the wire inside the gold prong and it seems right but, after that, the WiFi Signal is too weak. How can I fix this problem? There is some way to reconnect the gold prong and the wire?
Thanks!
2条评论
Please give us the make and model of your system.
You likely will need a replacement antenna cable. But without knowing who's system you have here I can't offer you more. Posting a good picture might be helpful as well.
由 Dan 完成的
Asus UX303L. The only way is replacement? Can´t I tin solder wire?
由 Ramon Paris 完成的
