跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
Identify error 1 problem when updating.
So after about a month or two that i fixed my iPhone the problem started to reappear and i mean it started to Searching for service. So to permanent fix (the last time i fixed it with the hairdryer) this issue i would like to know if there an easy way to identify if the power management ic causes the problem or the baseband ic itself (as error 1 is related to hardware issues)
Also is there any difference error 1 with error -1?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If it was searching for signal the stopped working then I suggest that the modem has stopped working. You did the worst thing possible by updating. The phone is clarified by Apple and I bet that the phone does not have an imei. Therefore iTunes throws up error 1 or -1
Nothing Can be done to fix this
这个答案有帮助吗?
得分 0
3条评论:
It was in the same situation when i i bought it and i then by accident it got working but the problem is that i don't know how!?!? Now i am trying to find a way to fix it again but this time once and for all. Also yes there is not an IMEI and the modem is blank( exactly what happened in the first place)
完成的
NO IMEI then no fix - Sorry
完成的
Even with reballing the ic?
完成的
添加一条评论
添加你的答案
georgekarapi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 90
