跳转到主内容
Why won't my laptop turn on?
My laptop was on and then it suddenly went off.
When I press the power button it flashes 5 time but doesn't power up, the charging light doesn't come on when plugged in.
Any help on how to fix this problem would be great thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Check the LED on your charger if it is flickering or if it makes any noise when "charging" as there is a possibility the charger to be damaged and not the laptop.
完成的
添加一条评论
1个答案
Have you tried wiping off the battery contacts with alcohol? How about your charger /adaptor if all trhee are good then your last chance will be the battery do you remember dropping it? When a battery falls a lot of rimes will get ruined, hope i was of help
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Izzi Hotson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 232
