How do I can do factory reset in Google htc nexus9 tablet
My google htc nexus9 tab got hang due to running of so many application at a time. The touch screen is not responding How do to the factory reset
Have you tried turning it on and off? So all the applications close? If you can, leave it until it runs out of juice or try taking the battery out (if possible)
这个答案有帮助吗?
If your device is on, turn it off.
Press & hold the Volume down button. While holding Volume down, press & hold the Power button until the phone turns on. You'll see the word "Start" with an arrow around it.
Press the Volume down button until you highlight "Recovery mode."
Press the Power button to start recovery mode. You'll see an image of an Android robot with a red exclamation mark (you may also see "No command").
Press & hold the Power button. While holding Power, press the Volume up button once. Then release the Power button.
Press the Volume down button until you highlight "Wipe data/factory reset". Then press the Power button.
Press the Volume down button until you highlight "Yes" (or "Yes - delete all user data"). Then press the Power button to select it.
After the reset is complete, press the Power button to select "Reboot system now".
When you're finished, restore your data.
That is "recovery" operation, not factory data reset.
the Settings menu has a feature for “factory data reset”. However, I cannot find the restore function on this Nexus 9. Google probably updated the tablet operating system and forgot to provide the restore function.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 5,182
1条评论
This question was migrated from http://meta.ifixit.com/Answers.
由 iRobot 完成的
