跳转到主内容
A candybar-style smartphone by BlackBerry RIM released in 2009.
No ring sound for incoming calls
I no longer have a ringtone sound for incoming calls or alerts.
I can make calls and talk and here my party but no ringtone.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Can use the phone but have no ring on incoming calls
完成的
添加一条评论
2个答案
最有帮助的答案
Hi @Jane DeLoge
On the Home screen, click the Sounds icon. Verify that your sound profile is not set to either All Alerts Off or Silent.
If you have assigned a ring tone or alert to a specific contact, on the Home screen, click the Sounds icon. Click Set Contact Alerts. Click the contact alert. Click Phone or Messages. Verify that the Volume field is not set to Silent and the Vibration field is not set to Off.
这个答案有帮助吗?
得分 1
1条评论:
I believe I got it working and it was sound buttons it rang for me will see
what happens tomorrow. Thank you
完成的
添加一条评论
Try plugging some headphones in and out to see if that helps do this multiple times will having music playing. Then try calling out and have someone call you to see if it resets it self.
这个答案有帮助吗?
得分 0
2条评论:
Sorry but that does not make it work. Thanks anyway...
完成的
Found this article which another person had the same issue with their ringer and cleared there data base. Keep in mind if you fallow the steps in the article it will delete all your data please backup your data before clearing your data. Click on the link to see the article.
http://support.blackberry.com/kb/article...
完成的
添加一条评论
添加你的答案
Tom 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 344
