跳转到主内容
BlackBerry's newest flagship that features a physical keyboard.
73 个问题 查看全部
Bluetooth Connectivity - getDisconnect - On Answering / Call Connected
My Blackberry Passport Silver Edition device is connected/paired with Jabra Bluetooth device. Either on receiving / dialing, when the call is connected, the connectivity with Blue Tooth (BT) gets disconnected after 3 seconds, again needs to change the select the mode of speaking at Bluetooth for every call. It becomes a hecti
c task, even while driving.
Also my BT is connected to another BB device - no such problems with it.
Kindly suggest a measure to rectify it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I have same problem with my lovely Passport and Jabra Mini headset, couldn't find any solution but I have an experience to share with you:
Try to install an android app (no similar for BB10 exist) to manage Bluetooth connection.
Like "Bluetooth Auto Connect" I myself used.
See here:
https://tunesgo.wondershare.com/android/...
This app reconnect selected devices every 5 seconds or else. With this alternative action I could solve my problem nearby 70 % but not solved completely.
True solution is:
-Install Jabra Service app but on BB is impossible. It is designed for Android.
- Then Install Jabra Assist & Jabra Connect apps. These two can be installed on BB but does not work unless Jabra Service become running.
Good luck. Be in touch with me via f.behdad@gmail.com
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Madan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 339
