跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
My phone keeps rebooting
So a few days ago, my phone took a hard fall on its back surface, opposite of the screen, and after picking it up i noticed it was powered off. So i opened it up, unplugged and plugged in the power cable, and it turned on fine. Everything was fine on there except that my phone kept restarting every 2-3 minutes. I investigated inside the phne as this kept happening for the next few hours and didnt find anything damaged on the front of the motherboard. The power port and the battery were fine, but i did go ahead and change the battery for a new one, still no luck. I restored my phone to factory settings and it didnt work either. Now i cant use my phone because i cant restore from back up due to it restarting 2-3 minutes. I investigated further and noticed on the back of the motherboard, this piece (metal piece wait PURPLE border) was corroded or damaged, and i also remembered that this part of the phone heats up quickly when i boot up my device. I was wanting to know could this be causing my reboot problem or is it the power IC chip.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi
Can you shear snap photo for the phone to help diagnose the issue
完成的
添加一条评论
1个答案
Hi
Check the battery connector
Good luck
这个答案有帮助吗?
得分 0
1条评论:
I did multiple times, I have also tested the connector with a multi meter and it is fully functional. It doesn't look damaged either.
完成的
添加一条评论
添加你的答案
Eddy Nates 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 75
