跳转到主内容
A 10-inch tablet co-created by Google and Samsung for the Nexus product line.
25 个问题 查看全部
My Nexus tablet won't connect to Wi-Fi
My Nexus 10 tablet used to connect to the internet just fine, but now I cannot seem to get the Wi-Fi to connect, even with a known working network. I tried to reboot my device, but it won't work.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
I have the same problem as Brent Hoefling message above.
WiFi is on and you can see a list of AP's. when I try to connect to a known AP with a verified password, it flashes that it is connecting, and then goes back to "saved"
I just factory reset my tablet still doesn't work ????????????????????
完成的
Mine works now, but I don't know what is different. I stopped using it for months because of this issue. the battery was completely exhausted. When I tried it again, I had forgotten that the WiFi wasn't working and needed it for something and charged it back up. of course there were lots of app updates, and since I had forgotten that the WiFi wasn't supposed to be working, It didn't seem strange that there were so many upadtes available.
Sorry, I can't help you with what happened, other than letting the battery go all the way down and sit in the bottom of my drawer for a long time. :(
完成的
添加一条评论
4个答案
最有帮助的答案
I was having a similar problem and came across this thread. To prevent similar issues as https://xkcd.com/979/ , I will post my findings.
It appears that PMF (Protected Management Frames) interfere with WiFi connections on the Nexus 10. My AP (Ubiquiti) had PMF set to Optional. When I set PMF to Disabled, my Nexus 10 connected right away.
这个答案有帮助吗?
得分 3
1条评论:
Eric, thank you! the PMF setting was exactly the issue and disabling it resolved my Nexus 10 connectivity issues!
完成的
添加一条评论
Most often, problems like these are caused by simple issues. As seen on the Nexus 10 Troubleshooting page, WiFi connection issues are most often caused by simple problems.
Make sure that WiFi is on and Airplane Mode is off. Either of these would stop you from connecting to a network.
这个答案有帮助吗?
得分 0
4条评论:
in my case, I know airplane mode is off, because WiFi is on and you can see a list of AP's. when I try to connect to a known AP with a verified password, it flashes that it is connecting, and then goes back to "saved"
完成的
Ditto. I can see the network, it says it's connected but the tablet isn't registering it. I rebooted, no luck.
完成的
Its the same issue for me, I have tried to install LineageOS 14.1 and 16 version. On LineageOS 16 version Wlan works but there is problem with casting/screen sharing. Any solutions to wlan would be welcome
完成的
@bhoefling
Did you fix your problem with wifi as my tablet has done the same??????????????????
完成的
添加一条评论
Maybe this is waaay late, but just had the same issue. After finding this thread I tried a few things and it seems to be the DATE; my tablet also got a dried out battery so the date was set incorrectly. After changing the date, magic!
Works fine now
这个答案有帮助吗?
得分 0
添加一条评论
Had ! Against wifi.
Removed automatic date and time.
Problem solved
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Olivia Lockhart 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 18
过去 30 天: 93
总计 4,437
