跳转到主内容
Released in October of 2014. This model, SM-G530H/DV Samsung Galaxy Grand Prime, comes in a White, Gray, or Gold casing.
How can I remove FRP lock from my Samsung mobaile?
I was hard reset my Samsung mobile ( GRAND PRIME (SM-G531H) ). Now I can't set up my device without entering the e-mail previously synced with this device. I didn't remember my old e-mail. so how can i unlock my device from FRP lock..?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 53
24条评论
Fortunately there are many ways to get rid of this issue. There is a complete method to UNLOCK FRP from Samsung Galaxy Grand Prime. You should give it a try, I'm sure this will help you.
完成的
That's not true. If the phone is already locked it is more difficult because the GP does not support OTG.
完成的
Wats the easiest way to remove a from lock on a S5 I bought and can't use plz help
完成的
along with many others i can get into a phone now because google has me lock out ...what control are they goin to want next its my phone i should be able to use it please help
完成的
i can remove this for you contact me on skpe "spotthemall"
完成的
显示更多的19条评论
添加一条评论
11个答案
最有帮助的答案
There are few methods available which can help you to Remove frp
Steps to remove frp using OTG cable:-
you can use OTG cable and place APK file in pendrive
then connect the OTG to phone
USB storage will appear
Install the APK file
and open it you will be in Setting
then click on Backup & Reset ->Factory data reset->Reset device-> delete All
or if this method fails or you does not own OTG cable, try another method
Samsung FRP unlock without OTG cable
这个答案有帮助吗?
得分 6
1条评论:
this metod power on all phones , read
https://frpbypass-gsm.blogspot.com
完成的
添加一条评论
Samsung FRP Unlock All Models All Security Patch guide here.
https://unlockerplus.com/all-samsung-frp...
这个答案有帮助吗?
得分 4
1条评论:
Yes this service can unlock any Samsung FRP lock device even Samsung Note 20 FRP Unlock as well.
完成的
添加一条评论
look at this tutorial
remove frp lock samsung 2016 100% tested
https://www.youtube.com/watch?v=YPFAJQZ1...
这个答案有帮助吗?
得分 2
3条评论:
完成的
Don't work all the time
完成的
完成的
添加一条评论
It is siple to remove if ur device locked!
Open device in lockscreen than make an picture after go in cameramode to galeri and try to send the picture example via email. Perhaps u cant send and devive will redirect you to securety options than disable cloude and wola ur device is open ;)
这个答案有帮助吗?
得分 1
1条评论:
disable what?
完成的
添加一条评论
You must download a aol app to remove it and will cost 20 dollars
这个答案有帮助吗?
得分 1
1条评论:
I was playing
完成的
添加一条评论
This one will probably work https://drive.google.com/file/d/0B3goqmz...
这个答案有帮助吗?
得分 0
1条评论:
not working link
完成的
添加一条评论
https://youtu.be/oyyGseKMbq8
这个答案有帮助吗?
得分 0
添加一条评论
frp lock remove please help me my phone g361f samsung
这个答案有帮助吗?
得分 0
1条评论:
完成的
添加一条评论
I have been looking for the same issue to remove FRP Lock from my Samsung Galaxy S7 Edge and I had found '''Samsung FRP Unlock Tool''', which has helped me to remove FRP Lock very easily. You need to be a bit technical.
这个答案有帮助吗?
得分 0
添加一条评论
Check here to know the all Latest Samsung Devices FRP Bypass problems-https://www.gadgetsdr.com/category/samsu...
这个答案有帮助吗?
得分 0
添加一条评论
Click here to find a complete solution to your problem ++https://minitipsx.com/samsung-account-lo...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
dilshankavindu 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 30
过去 30 天: 117
总计 86,349
