跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Do I need to purchase a heat shield plate or LCD digitizer?
My phone suddenly went blacked out and it couldn't be turned on after I delayed on replacing the bloated battery. The situation was so bad that my LCD screen was seen being pushed out slightly. Now that I have replaced the battery, the whole phone couldn't be turned on. To make things worse I accidentally scratched the heat shield on the shield plate as it had bent it slightly.
So my question is what should I do now? Should I purchase a LCD digitizer and give it a try? Does iFixit offer refunds if purchased items doesn't work out for their customers?
Thanks in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
The heat shield should not affect the phones functionality. Its there to protect the LCD from excess heat, but your phone should still power on without it.
The issue shouldn't be with the LCD if it was working prior to the install of the new battery.
Do you have more than one new battery?
Have you plugged the phone into the mains without the battery attached? If so what happened?
If the phone comes up with the fruit logo with the battery detached, then your issue was with the battery and you will need to get it replaced. Not all new batteries will function and if you do not have a battery booster you will need to get a new battery.
I hope this helps
这个答案有帮助吗?
得分 1
1条评论:
Actually the LCD wasn't working before the installation. It could have broke something in between.
I went to check it again and I think one of the three cables is dangling loosely and could be while installing I had broke that cable which links to the LCD.
完成的
添加一条评论
添加你的答案
Guang Ong 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 2,453
