跳转到主内容
Released in November 2013, this model of the HP 2000 series is the perfect device for those on a budget, but don't want to sacrifice performance.
34 个问题 查看全部
My laptop is stuck at the hp logo starting screen.
everytime i turn on my laptop it gets stuck at the loading screen and then turns black for a second then repeats. i tried removing the battery and holding the power button for 30 seconds and it still doesn't work. Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
- Have you tried checking your memory modules to see if they are seated correctly?
- If you have more then one memory module, you can test your modules by trying to start computer with each individual module.
- Is the hard drive full? 15% or less available space, the system will freeze.
- A bad hard drive can also cause the system to freeze. I would connect it to another computer and run a program called Crystal Disk Info to check the health of the drive. If it's in the yellow or red, I would pull off any important data before the drive completely dies.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
itzcristiano gaming 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 509
