跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1236 个问题 查看全部
Camera not working in camera app, but working in facetime and snapchat
So the camera is just black in the camera app, but works fine in other apps that utilize the camera.
Force closing the app, hard reset, and restore of the phone has been tried. Any other ideas?
Update (01/25/2017)
Full reset worked, by doing it via the phone.
I suspect that the fault lies in the back-up the customer had on their computer.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
5条评论
Do you have any other apps that use the back camera that work?
完成的
Yes. Snapchat works fine, for both front and back
完成的
maybe not enough storage, so couldn't take photos any more.
完成的
Hav you tried closing all applications down that may be using he camera? if you dont know how to do this double click the home button and swipe upwards to close the apps, then try the camera?
完成的
The phone has 25 GB avaliable so unfortunately not. Tried closing everything else, but no luck
完成的
添加一条评论
8个答案
最有帮助的答案
Whilst it may not help this case, but just as an FYI. The iPhone 5 back camera has a history of having a terrible connection. If the back camera goes (and the front still works), just try giving the external camera glass a firm press... This is normally enough to spring it back to life.
这个答案有帮助吗?
得分 2
1条评论:
Other than resetting every time the camera goes out, this is the only solution that’s worked for me. Thank you!
完成的
添加一条评论
Look above at the other answers and they tell you how to fix it
Hard reset your device
这个答案有帮助吗?
得分 1
添加一条评论
Delete and reinstalling the app helped me fix my issue. Upon reinstall, I just gave the app all the permissions it requested.
这个答案有帮助吗?
得分 1
1条评论:
It was issue with Camera app, and not Snapchat :-) But glad you solved you issue
完成的
添加一条评论
I went to Apple today and they wanted us to buy a new phone $319 or replace the camera $59, no guarantee on the camera replacement. Camera was working in all other camera apps, except for the Apple Camera app! Frustrating. I used iTunes to do a hard reset. No luck. Then I looked in the camera settings and I changed formats -> Most Compatible. For some reason High Efficiency was checked, and when I tried to take pics with this checked, nothing saves to the camera roll. We don't even get a preview. I hope this helps someone else! :)
这个答案有帮助吗?
得分 1
添加一条评论
If you see a closed lens or black screen when you open the Camera app, try these steps:
- Make sure that there’s nothing blocking the camera lens. If you’re using a case, try removing it.
- Force the app to close, then open the Camera app again.
- Restart your device, then open the Camera app again.
- If your device has a front and rear camera, try both cameras by tapping . If you see the closed lens or black screen on only one camera, take your device to an Apple Retail Store or Authorized Service Provider for more help.
I hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
my front camera work but my back camera all im seeing is black .. it only works on facebook
这个答案有帮助吗?
得分 0
添加一条评论
I had the same issue and tried all of the suggestions mentioned above but those didn’t work. I switched between the camera functions ie video, slo-mo, etc. then back to photo and it worked.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sonnicham 将永远感激不已
浏览统计数据:
过去 24 小时: 29
过去 7 天: 154
过去 30 天: 622
总计 76,426
