跳转到主内容
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
Can I replace logicboard to model MBP 2012 a1286?
Hi guys. I have question. I have MBP 2011 with almost dead logic board, and dead video.
So, i decided to replace logic board, and have question.
My model is a1286 (2011 year). If i buy logic board from a1286(2012 year) and replace it will it work?
Thx a lot:)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
logic board number 820-3330-B
完成的
Your systems series: MacBookPro8,2
完成的
添加一条评论
1个答案
已选择的解决方案
Generally, one can swap out the logic board from within the series your system is a member of. So in this case the group in the above link.
When jumping across different series things can get dicy as the logic board mounts as well as the heat sink & fan system may not line up. In this case you're lucky! They do.
Apple did not make any physical changes in the logic board layout only the CPU was upgraded in the 15" model for the '11 & '12 model years. Here is the choices: MacBookPro9,1
As a side note these are the last upgradable systems (RAM & SATA Storage) Apple made. It's the only REAL Pro's laptop system that can take the bangs and has the meat to be useful!
Come on Apple lets get a real pro's MacBook Pro! One that can be upgraded and has the deep storage a pro needs onboard.
这个答案有帮助吗?
得分 4
3条评论:
hmmm, strange. Check my model on apple.com, it writes MacBook Pro (15 inch, late 2011 г.), but,if i'm right, logic board in this model are 820-2915, and my is 820-3330. So, i already have motherboard from model 2012 MBP?
完成的
Are you confusing logic boards and the CPU/GPU's installed on them?
完成的
The 2011 MBP A1286 8.2 has USB 2.0 and the 2012 MBP A1286 9.1 has USB 3.0, so there was quite a bit of a change on the board.
But as far as I know you can swap the logicboards from 2011 to 2012 and vice versa. At least all the connections (e.g. display) should be the same
完成的
添加一条评论
添加你的答案
evgencherkashyn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 1,091
