跳转到主内容
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
433 个问题 查看全部
Internal and External HD Buisness
My iMac has a broken graphics card and I have no way of turning it on completely without having black and white lines across the screen. I took out my hard drive on my iMac and wanted to transfer the data and files to my Sony External HD and I already did the partition on the external but how am I supposed to do this on my Sony Vaio PC? Please help!
My PC doesn't read the iMac hard drive just says "Removable Disk (D:)"...
Thank you if you helped or even answered, you guys really help a lot of people and again thank you for that!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Do you think there is a way I could do it on my PowerBook G4 since they are both running the same exact software (10.5.8)?
完成的
添加一条评论
1个答案
已选择的解决方案
Different operation systems use different drive formats! So in this case your Mac used GUID but your Windows system uses FAT32 exFAT or NTFS as its native format.
Don't despair! There are extensions one can load on your Windows system to allow you access to the files on your Mac drive.
But! Only your created files will be accessible under Windows. As an example a MS Word & Excel or PDF's and lastly, photos. You will of course need Windows apps to access these, your Mac apps won't work under Windows natively.
Here's a good write up: 4 Ways To Read A Mac Formatted Drive In Windows
这个答案有帮助吗?
得分 0
3条评论:
Thank you but do you think there is a way I could do it on my PowerBook G4 since they are both running the same exact software (10.5.8).
完成的
mmm ... I think you open another can of worms here.
You can't run the newer Intel version of the apps that are on your iMac drive (your PowerBook is PowerPC based)
The second issue you will encounter is depending on the data file (i.e. MS Word) the older version of MS Word can't open the newer file type.
TXT, PDF's & JPEG files you should be OK
完成的
Okay thanks!
完成的
添加一条评论
添加你的答案
Elias S 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 76
