跳转到主内容
加入维修社区 - 创建账户
Wi-Fi版的iPad Mini 2指南。2013年10月22号发布同年11月12号上市。iPad Mini 2就是配备了Retina显示屏的iPad Mini,在更小尺寸的的7.9寸屏幕上拥有和iPad Air相同的像素。
Charging Problem - not charging
Hi
I have an ipad mini 2 - model A1489 - when plugged in on charge it shows the lightning indicator, showing it is charging, but never gets past 2% and will switch off straight away when its disconnected, which indicates its not holding charge either.
I've opened it to inspect it, looked at the circuit board under a microscope and can't see anything missing. This is, by the way, the first time its been opened.
Here's the fun part, its been used by a child so is likely to have been dropped, although no visible signs of damage or water damage. whilst on charge it reboots every 5-10 minutes too.
Could this be a worn a battery?
I've tried several different cables and I am using a good charger.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sounds like a faulty battery to me.
You'll have to get it replaced.
Just in case below :)
You can get the part from here:
iPad mini 2 Battery
Guide on how to replace it:
iPad Mini 2 Wi-Fi 电池更换
Replace a battery compatible with iPad mini 2 A1489 and A1490 model tablets. 23.8 Watt Hours (Wh). 3.75 Volts (V). Battery model A1512.图片
产品
iPad mini 2 Battery
$31.99
这个答案有帮助吗?
得分 2
1条评论:
Thats what i was thinking, it comes on with charge then dies as soon as you disconnect it. Thanks for your reply
完成的
添加一条评论
添加你的答案
Dan Hurst 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 1,598
