跳转到主内容
Why doesn't my computer turn on? Why doesn't it start/load in?
I got this Macbook from a friend and he told me that it didn't start.
I took it apart and went to town. There were missing screws everywhere (might cause grounding problems?). The keyboard is sticky so I assume some liquid damage, and other than the fact that the laptop looks like it's been torn apart (quite badly if I may say), it's a perfectly (cosmetically) fine laptop.
Here's what I've tried so far:
Replaced the battery
Tried to reset the SMC (Maybe worked?)
Getting Green light on the Magsafe 2 Charging light
Occasionally, I'll be able to turn on the laptop and maybe get 1/32 on the loading bar.
3-4 times I've been able to log in into the profile after some experimentation, but I haven't been able to repeat it consistently.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Unplug the keyboard cable, reconnect the battery, then plug in the charging cable (it should boot).
If it still does not turn on in this state, remove the SSD, use a SATA to USB cable to plug in a known working HD/SSD to the USB. With the keyboard plugged in, hold the option key and try booting into the known working drive.
Missing screws won't cause grounding issues, unless the big screws for the battery, or the square battery connector are missing, but it will still boot without these.
Check the underside of the board for liquid damage, and clean with 95%+ isopropyl if any is present (take a picture of areas affected before cleaning though, for reference if needed).
I suspect it is either the power button, sometimes working on it's own, or a fault with the SSD (formatting or bad drive). Try the above and hopefully you can narrow it down.
这个答案有帮助吗?
得分 2
添加一条评论
Have you tried another power cord. sometimes it is the cord that has the problem. I had this problem with my hp pavilion. I got a better cord so now it will power up but if you dont get the rihgt cord it may not charge like mine does.
这个答案有帮助吗?
得分 0
2条评论:
Yep, I have 2 chargers, tried them both
完成的
some of the connectors might be dead
完成的
添加一条评论
添加你的答案
Edward Hu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 273
