跳转到主内容
MBP won't boot if LCD cable is connected?
Macbook Pro won't boot if the LCD cable is connected. However, it the cable is disconnected and the laptop is connected to an external monitor, it boots up just fine and I can see the OS. Anyone have any ideas? Tried the SMC reset and PVRAM already. Thanks for suggestions.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Should also add, system is running El Capitan
完成的
No water damage. I might just try removing the whole top half and testing the top half from a working 2010 macbook pro. It almost seems like less work than getting to the cable by removing the glass.
完成的
添加一条评论
2个答案
最有帮助的答案
Check the LDVS cable for bent pins or corrosion. Any water damage or falls? What is the history of the problem?
这个答案有帮助吗?
得分 3
添加一条评论
Also check that the plastic pull tab attached to the LVDS cable is not damaged: it prevents shortcuts between LVDS connector pins.
MacBook Pro 13" Unibody 中期显示屏更换
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shane K 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 102
