跳转到主内容
Won't boot - question mark appears. part 2!
This is a follow on from
Won't boot - question mark appears..
To recap...
When I turn the powerbook on it chimes and eventually just shows the flashing question mark. The HD has been changed but same result.
It won't boot from the optical drive (holding C down, or not), it just ejects discs after about a minute.
BUT I did get it to boot from an external firewire drive, after getting advice from this forum. But when I ran disc utility (from firewire drive) it couldn't "see" either the internal HD or the optical.
Someone suggested I unplug the optical drive in case it was faulty and somehow it was dragging down the disc buss? Anyway, did this, but no change.
So, in my ignorance I thought it must be a faulty logic board, and I've just managed to replace that (thanks to this site!).
But, I STILL get the same question mark - I'm gutted!
Before I kick this into a recycling bin, has anyone any ideas what I could try next?
Thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
Hi Mayer,
Thanks for the reply.
I didn't know you could boot from an external drive!
I'm off to find an firewire drive to try it.
Getting my hands on an ext. firewire DVD might take a bit longer.
I'll report back any results.
Thanks again for the response, much appreciated.
这个答案有帮助吗?
得分 0
1条评论:
OK, I got access to a G5 and the little powerbook DOES boot from a firewire drive!
But, I opened disc utility and the only drive it sees is the firewire drive. It doesn't see the internal HD nor the optical drive.
Does this mean the end for the powerbook?
I'm certain the cable from the int drive is well inserted!
Any thoughts or advice?
Many thanks.
And one other thing, I did remove the third party RAM just in case it was the culprit, but it wasn't.
完成的
添加一条评论
最有帮助的答案
You've done the right test procedures. I would next try booting from an external firewire drive. Then an external DVD drive.
这个答案有帮助吗?
得分 3
2条评论:
完成的
Not going so well!
I finally got a firewire drive.
Trying to load OSX on it is proving interesting!
My main mac is a macpro.
If I put in an 10.4 disc, and run the install it thinks I'm loading it onto my macpro and won't give me an option to load it on another disc.
I found a 10.5 disc, which does give me the option of loading onto the external drive.
BUT, the drive needs formatted, and I get 3 choices. I'm trying to use the option that will allow the disc to be used as a boot disc for a powerPC mac, which would suit the powerbook. But when I try to install the OS, it tells me the disc must be formatted as a Intel boot disc (GUIDO I think it was called).
So, I've spent a lot of time getting nowhere!
As an educated guess, if the little powerbook won't load from a known good internal HD, nor it's optical drive, I guess the chances of the fault being easy to fix, and more importantly cheap to fix are slim?
My unqualified mind is thinking it's probably a logic board, and therefore beyond economical repair?
完成的
添加一条评论
I didn't see anywhere a suggestion for replacing the logic board. If it boots from the G5 installed system external firewire drive, use that drive and install it. If it's a 3.5" drive clone it.
First boot from the external and go to "about this mac" and see if the internal hard drive or optical drives are seen. If not, replace the internal drive, boot from the external and use SuperDuper to clone it after you have formatted it. http://www.shirt-pocket.com/SuperDuper/S...
I do not see a guide to replace the hard drive specifically but this guide will get you there: PowerBook G4 Aluminum 12" 867 MHz Logic Board Replacement
这个答案有帮助吗?
得分 2
3条评论:
完成的
Mayer,
IT LIVES!!
Many thanks for your answer.
I had already tried a different drive in the powerbook at the start, and was told it was a bootable drive with OS X on it, but it now looks like it wasn't!
I replaced the drive with a new drive today (following your last answer) and I'm delighted to say I've got the little thing working again. The optical drive is still dead and ate on of my discs, but the optical isn't too important.
Thanks again for your advice. Much appreciated.
PS There is a guide to replacing the drive on the powerbook (luckily I'd saved it as a bookmark - http://tinyurl.com/yca8bsy - but for some reason the title has been changed to something about a master password?
Great site this!!
完成的
It's great when we can work through a difficult problem and get a success! Come back anytime ;-)
完成的
添加一条评论
此回答最初是针对另一个问题
They all get ejected after about a minute.Toshiba satellite m40 batteries
I got a known good int HD and replaced the Toshiba satellite m45 batteries harddrive
这个答案有帮助吗?
得分 0
2条评论:
I tried with another OSX install disc,Toshiba satellite m55 batteries the original software disc that came with the powerbook and Toshiba satellite p205 batteries the hardware test disc too
完成的
Where did this come from? What Toshiba batteries? If this is a new question, please post it as such. You have me totally lost.
完成的
添加一条评论
添加你的答案
kwackman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 35
总计 1,706
