跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Why does front facing not work after screen replacement
Hello i replaced the screen on my 5s and now the front facing camera does not work. i try to flip the camera to front and it takes a picture instead. i have to clear all apps and then i can use regular camera again. the front facing camera does not work in any other app like snapchat. is there a fix for this or not. thanks for any help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
its not uncommon for one of two things to happen, the front camera flex is a little more delicate than others and can be damaged in the repair, ifixit sells replacements for not much money, they also often do not get plugged in straight. Open the phone back up, disconnect and reconnect the camera flex again and see if that fixes it.
这个答案有帮助吗?
得分 0
1条评论:
Thank you I will try that
完成的
添加一条评论
添加你的答案
shocker0390 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 64
