跳转到主内容
The Acer Aspire D260 is slim and lightweight netbook.
5 个问题 查看全部
Acer Aspire One d250 keyboard not working not even in BIOS!
It was just working perfectly one day ago but when I turned it on today it is not working at all...Iam unable to use it in BIOS...Even I cannot go in the Bios or press f2 or f12 or go into safe mode by pressing f8...Co not even one key is working...I talked to acer support agent and he is saying that it is a Bios issue and is not related to hardware and is asking for $60 to get it solved by their technician..I cant pay them because I dnt have a credit card and also it a big amount ._. and iam not taking my notebook to a local repair shop because there is a risk that they can damage it..!! So please help me :( The model of my Acer Notebook is 'Acer Aspire One d250' !!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
"If it's not a hardware issue", Get a USB Keyboard and plug it in. That should get you where you need to go..
这个答案有帮助吗?
得分 1
添加一条评论
Hi,
These are great netbooks but they are prone to the keyboards failing. I have 2 and have replaced the keyboards a couple of times on both. One way to check is to use a USB external keyboard. However don't forget that the USB sockets don't always startup until windows is fully opened. If the netbook can be switched on and windows starts then try plugging in an external USB keyboard. If that works it is your keyboard on the netbook that is at fault. If you are using win 7 it should allow windows to startup without having to access the keyboard so that you can try this. If you are on win 10 it is a bit harder but it still may work because win 10 starts the USB ports earlier. If it is the keyboard a new one is about £10 on ebay. Remove the old keyboard with an old credit card or similar and push the card corner down between the keyboard edge and the plastic at the top of the keyboard. The keyboard is held in with two lugs at the top and one either side that need to be prised out with the old credit card. When the keyboard is free gently lift it clear but be careful because it is connected by a ribbon cable into a clip connector. Lift the clip on the connector to free the ribbon cable. Installing a new keyboard is the reverse process. Good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
hearthacker3774 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 16
总计 1,664
