跳转到主内容
Verticlal White Stripes on MacBook 2009 LCD
I dropped my macbook yesterday. Now my screen only displays all black with white vertical stripes ever 3" or so. Is this permanent damage or do I Just need to try to re-seat a loose connection? The computer is 100% functional when hooked to an external monitor...
I'd imagine replacing the screen assembly is not worth the cost of the mac.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
It could be the LVDS cable or the LCD itself. Let's try something:
Open the Macbook into an Obtuse position (wider than 90 degrees open.) Do it a few times; Do any of the white lines change formation or position? If they DO, the LVDS Cable is more likely the problem.
If this technique does NOT produce any change in the distortions, then the LCD itself is more likely to blame.
Best Solutions:
EZ Mode - Buy an LCD Assembly! Here's a link to a 13 inch 2009 LCD Assembly. See our handy guide on how to install said LCD Assembly, it's much easier than the other options. It's about $100 total!
http://www.ebay.com/itm/LED-LCD-Screen-D...
这个答案有帮助吗?
得分 1
添加一条评论
It may be a loose connector if you have recently opened it up or had it repaired. If not then the likely hood is that it may need a new LCD.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
michaelwaldon83 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 174
