跳转到主内容
The Epson Stylus Photo 1400 Inkjet Printer prints high quality prints of up to 13" x 19". In addition, it supports cd/dvd printing.
Why does it keep telling me to close the cd/dvd guide
everytime i try to print it wont , it keeps saying close cd/dvd guide cover
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Is the cd/dvd tray open?
完成的
@fimbriano there is no cd tray incerted
完成的
I have this same problem and I have tried everything! And no it is not open
完成的
添加一条评论
1个答案
最有帮助的答案
There's a rubber feeder on the right side of the paper tray at the bottom. Clean it with rubbing alcohol the best you can, and do it while it's feeding paper through to get more of its surface cleaned. It fixed my PHOTO 1400 but it was very frustrating until I found the solution online.
https://www.dpreview.com/forums/thread/2...
这个答案有帮助吗?
得分 3
4条评论:
Thank you very much! This did the trick, however I didn't have any rubbing alcohol handy, so I used some glasses cleaning wipes
完成的
Thanks! This also fixed this issue for me! I wonder if the "rubber feeder" is available as a repair part? I.E. maybe these "dry out" and loose their grip, over time.
完成的
So this worked for me after hours of trying to figure this out, soi I am thankful. However, I am totally confused what the rubber roller has to do with a CD tray open close error??? This is really mis-leading and can have you on a wild goose chase. Once again, thank for NOTHING Epson!
完成的
Totally worked for me. Thank you to the original poster and to this answer. I had wasted almost an hour on this and even tried a different computer thinking it might have been software.
完成的
添加一条评论
添加你的答案
lou ann obrien 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 2,912
